mpbrix92
- Nov 30, 2015
- Sheboygan , Wisconsin
- 2009 Yamaha Nytro RTX, pretty much bone stock
does anyone happen to have clear pictures/ possible description of the spacers and washers for each gear in the chaincase? I swapped tracks last spring and happened to move in the process and now I’m struggling to figure out which washers and spacers go on the top shaft and I’m worrying I lost some parts, any help would be great thanks
SnowBandit
- Jan 31, 2004
- NH
- www.slednewengland.com
- 2009 Nytro xtx
Don't have any pics right now but I typically use the parts fiche to get a good understanding of how things go back together
mpbrix92
- Nov 30, 2015
Yeah I was using the schematics but it was kinda difficult to judge which spacers went where
mpbrix92
- Nov 30, 2015
I guess I’ll skip the top shaft and try to assemble the bottom and see what parts are left over
SnowBandit
- Jan 31, 2004
- NH
- 2009 Nytro xtx
I should be ripping mine apart this weekend and should be able to take pics. Just need to remember lol
mpbrix92
- Nov 30, 2015
Yeah if you could remember to that would be awesome, I was going to order the parts I thought I was missing but wanted to hold off so I only have to put in one orderI should be ripping mine apart this weekend and should be able to take pics. Just need to remember lol
mpbrix92
- Nov 30, 2015
I’ve looked at this post before I think the pics are old which is why they’re so hard to see but it helps
mpbrix92
- Nov 30, 2015
So I got everything together but have 2 issues, I forgot the tiny sprung between the two reverse gears will this be an issue? And the brake pads are stuck closed
Dr. FeeLGooD
If its the park brake pads they can be tricky to set. You will figure it out lol. I took the park brakes system off my sled. And I think you need the spring.
mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
You need the spring...and make sure the outer gear (that sandwiches the inner gear with that spring), sits in the correct position. It's easy to put in backwards..ask me how I know lol.
mpbrix92
- Nov 30, 2015
When I put the brake on it seems to have some wiggle room is this normal?
