SharkAttak
ApexDriller said:http://www.youtube.com/watch?v=y2y7iN3G4gY
you crushed that srx, was the srx stock?
dirkdiggler
Suspended
SharkAttak said:ApexDriller said:I lean her forward as much as I can with control rod, soften front shocks to the max, rear EC suspension is set at lowest at start of race ( I stiffen it to the max after takeoff, seems to work at last 200 feet of race you get better speed with rear suspension stiffest). Everything is greased and track is loose but no ratcheting. i also use a belt with 2000 miles on it (my lucky belt I guess just for drags). Nytro was 4-5 sleds ahead of me at start but i'm reeling him in at about 500 ft, if race was 750 it would be tie IMO.
those Nytro's are real fast for short distances
I have a Nytro and the Apex's I've raced can't get around me on Top.
SharkAttak
dirkdiggler said:SharkAttak said:ApexDriller said:I lean her forward as much as I can with control rod, soften front shocks to the max, rear EC suspension is set at lowest at start of race ( I stiffen it to the max after takeoff, seems to work at last 200 feet of race you get better speed with rear suspension stiffest). Everything is greased and track is loose but no ratcheting. i also use a belt with 2000 miles on it (my lucky belt I guess just for drags). Nytro was 4-5 sleds ahead of me at start but i'm reeling him in at about 500 ft, if race was 750 it would be tie IMO.
what are you seeing on top end?
SledFreak
- Feb 7, 2005
- Ontario. Canada
I seen 114 speedo (110GPS) with my XTX on top end... This was on a snow/ice plowed road, pushing 3" of powder.
SharkAttak
SledFreak said:I seen 114 speedo (110GPS) with my XTX on top end... This was on a snow/ice plowed road, pushing 3" of powder.
that's real good, i like the nytro's they are very impressive
dirkdiggler
Suspended
SharkAttak said:dirkdiggler said:SharkAttak said:ApexDriller said:I lean her forward as much as I can with control rod, soften front shocks to the max, rear EC suspension is set at lowest at start of race ( I stiffen it to the max after takeoff, seems to work at last 200 feet of race you get better speed with rear suspension stiffest). Everything is greased and track is loose but no ratcheting. i also use a belt with 2000 miles on it (my lucky belt I guess just for drags). Nytro was 4-5 sleds ahead of me at start but i'm reeling him in at about 500 ft, if race was 750 it would be tie IMO.
I've seen 111 now. I actually raced another real good running Nytro and a Mach Z 1000 from a 30 mph roll on Sunday and never saw them again. I had nothing for them out of the hole on the glare ice but from a roll I got just enough bite to pull out and stay out front.
SharkAttak
dirkdiggler said:SharkAttak said:dirkdiggler said:SharkAttak said:ApexDriller said:I lean her forward as much as I can with control rod, soften front shocks to the max, rear EC suspension is set at lowest at start of race ( I stiffen it to the max after takeoff, seems to work at last 200 feet of race you get better speed with rear suspension stiffest). Everything is greased and track is loose but no ratcheting. i also use a belt with 2000 miles on it (my lucky belt I guess just for drags). Nytro was 4-5 sleds ahead of me at start but i'm reeling him in at about 500 ft, if race was 750 it would be tie IMO.
why is yours so fast, what are your mod's?
ApexDriller
SharkAttak said:ApexDriller said:http://www.youtube.com/watch?v=y2y7iN3G4gY
The SRX is not stock, he's done alot of clutching, gearing and piping, he also long tracked it to 136". It has unreal top end tho. His wife's 2002 SRX bone stock gives me a better challenge. He knows alot about Yamaha, his Dad used to own Yamaha dealership and race on the old circuit. He knows his stuff and he just happens to love tinkering and working on my 4 stroke as well
SharkAttak
ApexDriller said:SharkAttak said:ApexDriller said:http://www.youtube.com/watch?v=y2y7iN3G4gY
The SRX is not stock, he's done alot of clutching, gearing and piping, he also long tracked it to 136". It has unreal top end tho. His wife's 2002 SRX bone stock gives me a better challenge. He knows alot about Yamaha, his Dad used to own Yamaha dealership and race on the old circuit. He knows his stuff and he just happens to love tinkering and working on my 4 stroke as well![]()
i know the 121" srx on top end is real fast, i was just surprised how bad you beat him by
ApexDriller
I usually GPS at 110-111mph on packed snow and I've hit 116mph on local lake airstrip (3/4 mile ice). This year it's not the same, seems like I've lost 10 mph on top end and sucking back the fuel (almost double). I got a feeling it's donuts or Y-pipe cracked. Going to have a looksee this weekend.SharkAttak said:dirkdiggler said:SharkAttak said:ApexDriller said:I lean her forward as much as I can with control rod, soften front shocks to the max, rear EC suspension is set at lowest at start of race ( I stiffen it to the max after takeoff, seems to work at last 200 feet of race you get better speed with rear suspension stiffest). Everything is greased and track is loose but no ratcheting. i also use a belt with 2000 miles on it (my lucky belt I guess just for drags). Nytro was 4-5 sleds ahead of me at start but i'm reeling him in at about 500 ft, if race was 750 it would be tie IMO.
SharkAttak
ApexDriller said:I usually GPS at 110-111mph on packed snow and I've hit 116mph on local lake airstrip (3/4 mile ice). This year it's not the same, seems like I've lost 10 mph on top end and sucking back the fuel (almost double). I got a feeling it's donuts or Y-pipe cracked. Going to have a looksee this weekend.SharkAttak said:dirkdiggler said:SharkAttak said:ApexDriller said:I lean her forward as much as I can with control rod, soften front shocks to the max, rear EC suspension is set at lowest at start of race ( I stiffen it to the max after takeoff, seems to work at last 200 feet of race you get better speed with rear suspension stiffest). Everything is greased and track is loose but no ratcheting. i also use a belt with 2000 miles on it (my lucky belt I guess just for drags). Nytro was 4-5 sleds ahead of me at start but i'm reeling him in at about 500 ft, if race was 750 it would be tie IMO.
i'm going to doing a lot of work on mine after the season too
dirkdiggler
Suspended
SharkAttak said:dirkdiggler said:SharkAttak said:dirkdiggler said:SharkAttak said:ApexDriller said:I lean her forward as much as I can with control rod, soften front shocks to the max, rear EC suspension is set at lowest at start of race ( I stiffen it to the max after takeoff, seems to work at last 200 feet of race you get better speed with rear suspension stiffest). Everything is greased and track is loose but no ratcheting. i also use a belt with 2000 miles on it (my lucky belt I guess just for drags). Nytro was 4-5 sleds ahead of me at start but i'm reeling him in at about 500 ft, if race was 750 it would be tie IMO.
Filters,Header,Plugs, PC111, Ignition Module Extra Wheels in the skid to reduce drag on the hyfax. It's also clutched.
SharkAttak
dirkdiggler said:SharkAttak said:dirkdiggler said:SharkAttak said:dirkdiggler said:SharkAttak said:ApexDriller said:I lean her forward as much as I can with control rod, soften front shocks to the max, rear EC suspension is set at lowest at start of race ( I stiffen it to the max after takeoff, seems to work at last 200 feet of race you get better speed with rear suspension stiffest). Everything is greased and track is loose but no ratcheting. i also use a belt with 2000 miles on it (my lucky belt I guess just for drags). Nytro was 4-5 sleds ahead of me at start but i'm reeling him in at about 500 ft, if race was 750 it would be tie IMO.
YamerHammer
This is all I have to say......I was ahead from start to finnish. This is my cousins XTX and I.
http://www.youtube.com/watch?v=FMZxcRTCDu4
ApexDriller
You should be out in front with all the extras you got, good job.YamerHammer said:This is all I have to say......I was ahead from start to finnish. This is my cousins XTX and I.
