thunderbolt
I ride a 2011 apex se with fox float suspension , my wife rides a 2010 vector gt with the coil over shock style suspension , how come with no weight on either machine sitting level in the garage her sled is apox. 1 inch higher from the bumper to the floor in the rear , is there anyway to adjust the ride height on the apex with the fox floats?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Different skid
thunderbolt
I know its a different model sled , but saying all that my 2007 apex was the same chassie as the 2010 vector and it also was inch lower in the back
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Does the sleds have different skids?
snowbiscuit
air pump
That's what the pump is for
thunderbolt
so by pumping up the fox mega shock will increase the ride height ?
snowbiscuit
height
If you want the back end down in theory you can increase pressure in the front floats or reduce it in the rear(Mega) or both and naturally vice versa if you want to go in the opposite direction. For me I run 45psi in front and 150 in rear....this will give a raked look but is the way I like it for handling........along with 13mm bar
