APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
I'm wondering if someone can tell me the bearings and sizes that are in a 2011 Apex XTX chaincase side. I don't want to buy the All Balls kit as I've heard that they aren't really a great bearing to put in a very important part of the drive lines. I've found so many conflicting bearing sizes on here and I just want to make sure I order the right ones.Thanks
most of them are common truck pilot bearings from what i remeber. i put the all balls kit in my 2011 apex xtx 5000 miles ago and they where all fine when i checked it while i was changing the track pre season. i think it is the speedo bearing and the one behind the secondary that give the kits a bad rap but i repack those annualy and have had no issues.
APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
Thanks! I did find the 2 driveshaft bearing NTN #'s from Royal Dist. but it doesn't have a the jackshaft/chaincase side listing.
Here are my notes and list I made... (I have one for my 06 Apex as well)
2015 Apex XTX:
Rear Suspension:
*OEM, Replacement Royal p/n's
-2×'s 6304? Yamaha Marg W-Kit, 85mm*, (3.325") Kimpex #04-116-105P, p/n: 298887 ($30.49)
-2×'s 6005 Front Shock Shaft 130mm*, 5.118" (130mm) Yamaha 04-116-96S ($27), 135mm Kimpex #04-4135-20 ($39) (#298991)
-2×'s 6005 Front Outside of Rails 130mm*, 5.118" (130mm) Yamaha 04-116-96S ($27), 135mm Kimpex #04-4135-20 ($39) (#298991)
-2×'s 6205 Uppers 7"*, 7.125" 04-116-79 (BLK) ($30)
-2×'s 6004? Yamaha Marg W-Kit, 85mm*, (3.325") Kimpex #04-116-105P, p/n: 298887 ($30.49)
-2×'s 6205 Mid Outside of Rails 135mm*, 5.630" 04-116-75 ($29)
-4×'s 6004 Rear Axle 7"*, 004-11698BK (BLK) ($28), 7.125" 004-11694 (BLK) ($33)
DRIVELINE:
Number on bearing*/Royal Distributing p/n.
-Driveshaft:
Clutch side: 205*/04-156-03OR
Chaincase:
Housing: 6205*/04-156OR
Cover: 6007*/04-058030
-Jackshaft:
Clutch side: 6305RD-Koyo
Chaincase:
Housing: 6206*/04-159OR/04-165OR
Cover: 6205*/04-156OR
2015 Apex XTX:
Rear Suspension:
DRIVELINE:
-Driveshaft:
Chaincase:
-Jackshaft:
Chaincase:
