Yamablue
- Feb 1, 2005
- Twin Cities, MN
- 2011 Nytro RTX SE, 2002 Viper, 2002 Viper ER, 99 VMax500Dlx
Hey guys, I pulled the trigger on a mountaintech 43+2 front end for my Nytro and was wondering if anyone ended up changing out the swaybar for something like the Schmidt Bros bar. Is is the stock one just fine with the new geometry. I asked Peter, but he's a mountain rider and doesn't have much experience on a 121.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
If you have the 11 RTX SE, then you likely have a 13.5mm sway bar. The non RTX models actually have a stiffer 15mm sway bar. I have several good used ones if you want to try a stiffer bar for flatter cornering. $75 for one.
Kurt J
- Apr 10, 2019
- Michigan
- Nytro, Apex
I have the Schmidt Bros. Swaybar on my Nytro with Skinz Concept 42” arms. I posted a little about the installation here, previously. The handling is better, and gets rid of a lot of the flip/flop that happens when decelerating from high speeds.
