macpat
- Nov 6, 2009
- South Porcupine, ON
- www.gotsnow.ca
Looking to find out the highest risers I can get for my XTX without having to move cables?
I'm running 3" plus an OFT relocator(+2"). Did have to re-route the trottle when installing the relocator though.
macpat
- Nov 6, 2009
- www.gotsnow.ca
So 3" would be okay? I am not going to use the relocator...
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
Why not use the relocator, it is by far the best upgrade to my nytro for steering angle.macpat said:So 3" would be okay? I am not going to use the relocator...
I suggest the relocator before anything. Probably the best update you can do to a nytro.
Confused?
How is the relocater different from a pivot riser? Sorry bout the hijack.
macpat
- Nov 6, 2009
- www.gotsnow.ca
maxxp said:I suggest the relocator before anything. Probably the best update you can do to a nytro.
Thanks for the suggestion guys but I am not planning on adding the relocator. I just need to increase their height of the bars since I am a taller rider.
Does anyone one know how high I can go before I get into problems with break/throttle cables?
Confused?
I put a 5" riser on my 121 that has the 3" handle bars and its about an inch to tall with no relocation of the cables.
leeman13
- Dec 4, 2011
- Winnipegosis, Manitoba
- 2012 Yamaha Nytro
I just put a 3 1/2 inch riser on my 2012 xtx, but had to reroute the throttle cable underneath all the other wires and cables and reroute the emergency cable behind the rad. Want to put a oft re locator on yet to which will give me more room I believe. The only one that is a little tight is the brake line. But only at full left turn otherwise it's ok.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
macpat said:maxxp said:I suggest the relocator before anything. Probably the best update you can do to a nytro.
How much rise are you looking for? The relocator gives you about 2 inches rise. I'm 6'3" and it perfect with the stock riser. Just a thought
macpat
- Nov 6, 2009
- www.gotsnow.ca
sorenson1610 said:macpat said:maxxp said:I suggest the relocator before anything. Probably the best update you can do to a nytro.
I am 6'5", not really sure, I had 5" on my mountain max before the nytro. I would like to stand up comfortably on the sled. Was going to try to figure out the height at some point before I order anything.
Ryanb.nytroxtx09
- Nov 30, 2012
I'm 6" and i have a 2in bar riser. it's a 2" Rox Riser (adjustable). no problems and it's perfect!
-09 nytro xtx
- skinz Ultra Q exhaust
- 8" Bergstrom Triple Point Carbides
- 2" Rox Riser (adjustable)
- Yamaheater Hand Warmer module
- HyGear rear torsion spring spacers
- 12v accessory plug
- Wired for heated shield
-09 nytro xtx
