2012 apex xtx handling..
gmcman2012
Denmark, ME
hey guys i am looking at up grading my sway bar to a 13 mm any thoughts on this would be helpful. thanks
I was thinking the same on my xtx 2011 it wouldn't hurt should help a little.
ya i am hoping it helps to. i guess my post are bad cause i only get one answer on every post i do...............
Do your homework (search) before deciding on the 13mm swaybar.
I was also thinking of one for my 08 Vector but I have read that it increases negative feedback to the bars.
I have read where some have tried it then removed it due to this so I personally decided to forget about one.
I bought one, installed it on an 07 Attak I previously owned. As Irv has stated, I promptly took it off for the very reason stated. Every little bump was transferred right up through the bars and into my hands. I couldn't stand it!
After reading others opinions of this mod on an EPS equipped Apex, I figured I'd give it a try on my SE. Wow! What a great addition it made on this sled! The slight additional feedback felt in the bars on the SE is well worth it for the improved cornering. IMHO the EPS makes the difference.
I recommend it!
thanks guys this really helps that's what some people have said about the eps models but i wanted some more feed back. did you get yours from pioneer performance. thanks again
I think I bought mine fron Pioneer. It was several years ago.
"The mind is the second thing to go! .... I think!" :o|
