Joeski
- Oct 25, 2019
- MI
- 2013 RS VECTOR LTX
Have a 2013 Vector LTX. I am looking for the stock mono shock spring part number or spring rate. I need to upgrade to a heavier spring. Pushing 300lbs with gear. When I search Yamaha alternative rear springs it show four different springs and rates but I’m not sure where the stock one is compared to them. I talked to four different dealers but they didn’t know. Any help would be great, thanks.
Gotrek
- Dec 28, 2019
- Winterpeg
- 2008 vector rs l-tx
Ever figure this out?
Joeski
- Oct 25, 2019
- MI
I ordered one from barn of parts that’s a progressive 5-8kn, he told me mine was a 5kn.Ever figure this out?
Gotrek
- Dec 28, 2019
- Winterpeg
Thank you. Do you like it? I figured I'd do the same or try the Hygear setup
Joeski
- Oct 25, 2019
- MI
I haven’t ridden it yet but I just took off my Hygear shock, dual spring rate axis shock. I couldn’t dial it in to get the plush ride my stock shock gave. It was either jittery or harsh on the stutters so I’m giving this a shot, hope it works. It worked for big bumps but our trails don’t see over 4” bumps by me.I ordered one from barn of parts that’s a progressive 5-8kn, he told me mine was a 5kn.
Gotrek
- Dec 28, 2019
- Winterpeg
If you get snow before we do let me know how you like it
I plan on getting something for next year (for my 08)
Joeski
- Oct 25, 2019
- MI
Sure I’ll let you know.If you get snow before we do let me know how you like itI plan on getting something for next year (for my 08)
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
I did some research as this is the same shock/susp I run & it appears stock was 4.49kg, the optional higher/heavier than that is #8hv-22212-20-00(4.99kg) & heaviest#8hw-22212-10-00 (5.99kg) based on what guys did with the older apex/attak the guys over 300 used the heaviest springHave a 2013 Vector LTX. I am looking for the stock mono shock spring part number or spring rate. I need to upgrade to a heavier spring. Pushing 300lbs with gear. When I search Yamaha alternative rear springs it show four different springs and rates but I’m not sure where the stock one is compared to them. I talked to four different dealers but they didn’t know. Any help would be great, thanks.
Joeski
- Oct 25, 2019
- MI
That was my original plan but after talking to barn of parts, I decided to try his progressive spring, said he had good feedback on it.I did some research as this is the same shock/susp I run & it appears stock was 4.49kg, the optional higher/heavier than that is #8hv-22212-20-00(4.99kg) & heaviest#8hw-22212-10-00 (5.99kg) based on what guys did with the older apex/attak the guys over 300 used the heaviest spring
I have the 5 mutli from BoP. Together with my revalved shock it provides a great ride in the trails.
