turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
So... my buddy hooked up his battery tender backwards and now no power , he checked the fuses and all check out good. still no power to dash or starter??? Any ideas?
if the main fuse by the solenoid is good, it could be the battery is toast.
turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
Got the whole story now. Wasn't hooked up backwards but shorted to ground when he hooked up the battery. He said battery tested good.if the main fuse by the solenoid is good, it could be the battery is toast.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Did you check the 30A fuse by the starter relay?
what kind of tester? i have had the toaster one lie to me at times.Got the whole story now. Wasn't hooked up backwards but shorted to ground when he hooked up the battery. He said battery tested good.
