motoseth290
- Jan 27, 2020
- Machesney park, Illinois
- 2014 Sr viper xtx with mpi 190 turbo kit.
First off I want to say that I've read allot of the posted forums and couldn't find exactly what my sled is doing.
I installed a mpi turbo kit 190 with the eabc and everything went smoothly. But now I'm experiencing shut downs when putting around or on deceleration. Trying to make a turn from a Tee intersection sometimes it will just stall out.
When you on the throttle there's no problem at all.
The kits pushing 5psi from what the gauge tells me.
I dont have an afr gauge yet will have one in the next few days.
Anyone have any information on what to look for or should I just wait and install the afr to see what I'm running at idle and low speed.
Sled never did this before only after turbo was installed.
Thank you in advance!!
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I had the exact symptoms you just described after installing mpi turbo also, in my case I needed to adjust my throttle cable, it was just a tad tight, hope this helps if so it's an easy fix.
motoseth290
- Jan 27, 2020
Murdered141 I read that, I'm hoping that's all it is. The more I think about it I think it may be. It also kinda wants to run away a little bit if that makes sense.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
It was driving me nuts all last season, got it sorted out towards the end, put in a new throttle cable this year and it's even better now
motoseth290
- Jan 27, 2020
Yeah, it's already driving me insane, I'm planning on taking a trip in the next few weeks and I want to get this issue resolved. I'm hoping that it's just the throttle cable being out of adjustment.
Is there a set allotment that the throttle is supposed to move? I think I read like 2-3mm
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
That sounds about rightYeah, it's already driving me insane, I'm planning on taking a trip in the next few weeks and I want to get this issue resolved. I'm hoping that it's just the throttle cable being out of adjustment.
motoseth290
- Jan 27, 2020
I'll give that a shot tomorrow and check back in with the results
motoseth290
- Jan 27, 2020
Just wanted to say thank you!! I went and adjusted my throttle a little bit, and bam now the sled runs perfect. Even starts easier too.
Thank you again!!
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Glad I could help, that's what this site is all aboutJust wanted to say thank you!! I went and adjusted my throttle a little bit, and bam now the sled runs perfect. Even starts easier too.
Thank you again!!
