06apexak
- Feb 7, 2007
- Willow, Alaska
- 2006 Yamaha Apex RTX
Just tried to start the sled and no power to dash when key is turned on. Motors does not turn over. Kill switch is on, all fuses that I can find are ok, battery reads 13.5 volts. 400 miles. Never had this issue before. Still trying to find the relays. I’m terrible at troubleshooting electrical. Anyone experience this issue? Solution?
hydraulic yam
- Nov 12, 2025
- Mt Albert, Ont
- 2013 Apex XTX
93 Yamaha VKII, assorted fluid drive Yamahas
I'm expecting this is new enough to use the 4 stroke and has similar wiring to the
newer Apex , Lots of suggestions when you google your exact issues . They all lead back
to this site for solutions, but not always your model. Apex etc.
Frozen relay ?? BUT my Apex is full of bridge clips and the ground versions corrode
and lose contact . Some can be cleaned , some are eaten away. My headlight had
the cap melted away and dark inside . Some will clean and others cut , strip and solder them.
There are some good pictures on site. They are usually black , size of a little finger tip
and have a cluster of black and sometimes brown wires leading into them.
Try a heat gun (not melt gun) on relays first.. they seem to hide them in left foot board.
https://www.partzilla.com/catalog/yamaha/snowmobile/2017/vk-professional-ii-vk10fhs/electrical-1
Desperate act would be to carry wire strippers and a mar connector for "field" repair.
Currently my screen shows "similar threads" at bottom. 1st one is "wont start- no power to dash"
good hunting
Ron
good hunting
Ron
on the carbed sleds, the relays where above right footwell. on the efi sleds, they where mounted above the left footwell.
have you looked at the starter solenoid for dirty contacts on the plug in?
