machz69
I know there is a gearing chart but I never seem to get the right mph?? what mph should this gearing be good for?.. is this stock gearing for an 06 attak?
out-front-Y
125mph
machz69
thanks
Sled Dog
According to my gear to speed calculator I only get 111 mph need to know rpm efi or carbs overdrive clutch or not. You can use it yourself the link is in my sig.
machz69
i get 126mph
Sled Dog
What parameters are you using?
machz69
1.1765
23
38
2.52
9
1.1765
23
38
2.52
9
Sled Dog
And your rpm is what at WOT
Sled Dog
ok I see your using the overdrive clutching.
DooAssassin
You get 126MPH with stock gearing? I think the actual speed is alittle slower. I saw 126 on my speedo and gps was actually 111mph. No spinning on grass/ 1 in snow
machz69
This is not actual speed, this is calculated maximum speed the gears can put out. Right now I'm just trying to set up for 660' and not so much top speed. I do have other gears for speed but I'm more worried about the track coming appart at high speeds. Your running a 1.5 track, what size are your drives? are you studded?DooAssassin said:You get 126MPH with stock gearing? I think the actual speed is alittle slower. I saw 126 on my speedo and gps was actually 111mph. No spinning on grass/ 1 in snow
Sled Dog
Its calculated he is using a overdrive clutch which in essence gives him a higher gearing but the motor has to be able to pull it to 10200 to give him that speed.
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
machz69 said:I know there is a gearing chart but I never seem to get the right mph?? what mph should this gearing be good for?.. is this stock gearing for an 06 attak?
If your clutch is stock with any clutch kit added and no overdrive and you have 23/38 in the chaincase running 10500rpm your real speed is 111.73 on hard pack snow.I did some testing with different gearing set up with my radar gun on hard pack snow last winter and the caculator is bang on.
Tach RPM: 10,600
Clutch Reduction: 1.2333 -
Clutch Ratio: 1.0000 -
Top Sprocket: 23
Bottom Sprocket: 38
Track Pitch: 2.52 -
Driver Teeth 9
MPH ------------------ 111.73
KPH -------------------- 179.81
machz69
Are you saying you can push into overdrive?
helmic
- Nov 10, 2008
overdrive
If you get the motor side clutch overdrive disc installed on your clutch yes you can.I have one for sale if your intrested.
machz69 said:Are you saying you can push into overdrive?
