fourndog
Does anyone know anything about what exactly needs to be done at 500 miles besides an oil change?
MR.HAPPY
- Sep 30, 2003
- GREAT NORTH OF... ILLINOIS?
- YAMAHA
I did a oil change, filter change, carb sync, [now throttle body] adjust chain, look at chain case oil, track tension, grease everything, check bolts & screws for tightness & rode the rest of the year!!!
GOOD LUCK!
BR
GOOD LUCK!
BR
tmk50
The only thing I would add to that is checking the coolant level (a little more difficult on the Apex's)
fourndog
how do you sync the throttle bodies?
paulrxwarrior
fourndog said:Does anyone know anything about what exactly needs to be done at 500 miles besides an oil change?
You're going to have to change your pants after coming off that SRX....
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
Your manual tells you when and what to do. It should have come with the sled. I remember something else needs to be done also, then not again until 25,000 mile mark. Your book will tell ya all you need to know.
1CS
1CS
