2008 Nytro RTX
Need some Headlight Fluid,I think I am going to run full synthetic in it. Not sure though,Can you help me?arteeex said:2008 Nytro RTX said:I am running 0W-40 Mobile 1 and 0 problems so far,So I am more then likely just going to keep using it.
Glad we had this little exercise. What can help with next? How's your coolant? Grease for the skid? Headlight fluid?
jeffT
I'm havin trouble finding blinker fluid, tie rod end wires, and a spare muffler belt. The grocery store had none in stock but I did pic up a board stretcher while I was there
skidooboy
better pick up a can of beep while your at it. your horn sounds pretty weak. ski
2008 Nytro RTX
No need,Heard Yamaha has a recall on it. Bring it to your dealer ASAP for no charge to you.skidooboy said:better pick up a can of beep while your at it. your horn sounds pretty weak. ski
My tie rod end wires are real lose,Would this cause a short and prevent the sled from starting?
06RSRAGE
- Jan 16, 2006
- Upstate NY (Colton)
- web.me.com
RIGIDONE said:I run Opti-oil 5w30 in both my 07 Phazers, good to flow up to -60.
Did you say -60... on Phazers in Syracuse... you do live in Syracuse NY not somewhere named Syracuse Alaska, BC or Antarctica.
06R
