Metallicat
Went to the local dealer the other day and asked for the Yamalube 4 stroke oil for snowmobiles. I was sent home with the 5W-30 cold weather oil. I don't think they even knew about the 0W-30 blend (and in fact I didn't either until getting home and doing a little research here).
The 5-30 should be okay to use, right? I figure I can use it the rest of the season and then change again next fall to the 0-30 formula.
What do you think? Use it or return it and go somewhere else for the 0-30 oil?
This is for a new Vector.
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
I think Yamaha switched after the 04 sleds to 0w-30 in 05 and I believe it was mainly to help starting in extreme cold. But I could be wrong.
AKrider
My dealer seels the 5w-30 and I've not had any issues. But, I live along the coast and rarely see temps below zero.
Shaf
Put it in the freezer overnite and then try to pour it out, that should answer your question.
rough rider
oil
Thats what originaly was used in rx1 when they came out, then they came out with 0-30 weight, if its not super cold u can use the 5-30. thats what I run in all my 4 stroke atvs
Metallicat
0W-30 pours much better than 5W-30 when left in the freezer? I could put it in the freezer but all I want to know is if it is okay to run in my sled!
Shaf said:Put it in the freezer overnite and then try to pour it out, that should answer your question.
LazyBastard
The answer is YES, you can put in just about any kind of oil you like and it will be fine.
Metallicat
Cool. I will save about $5 in fuel by not returning it!
LazyBastard said:The answer is YES, you can put in just about any kind of oil you like and it will be fine.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Yes, Yamaha changed the viscosity for better cold weather flow. Next year go to an even better oil and weight with amsoil 0W-40
Metallicat
Mighty - is there any concern with the starter clutch an using normal "car" synthetic oil?
Mighty said:Yes, Yamaha changed the viscosity for better cold weather flow. Next year go to an even better oil and weight with amsoil 0W-40![]()
LazyBastard
No.
Traildale
I was told by 2 Yamaha dealers to use the 5w-30 for th first 2000 miles or at least for the first season. Then switch to the semi-synthetic 0w-30 thereafter. Same advice I've heard for years - break in on standard oil before switching to synthetic. Is that really necessary? Your call.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Like LB said; no. Plus their 0W-40 isn't car oil.Metallicat said:Mighty - is there any concern with the starter clutch an using normal "car" synthetic oil?
http://www.amsoil.com/StoreFront/aff.aspx
Metallicat
Nice! I'll run the 5-30 for the rest of the year then probably switch to the Amsoil 0-40 next year!
Thanks for the update!
Mighty said:Like LB said; no. Plus their 0W-40 isn't car oil.Metallicat said:Mighty - is there any concern with the starter clutch an using normal "car" synthetic oil?
