rxwhopper
tried 89a 10 setup i got from a frfiend who has a very respectably fast rx, it is 89a 10, 14.5 rollers,ora,silv. oran, primary, 4.5 gram in tip , heel empty,,unfortunatly he was running studs on a shorty, im running a 1 1/4 on a 151, when i hit it it goes to about 10800 then comes down to 103 and pulls good, traction is bad due to lack of snow, i am running a hitech 48-46 withpolaris silv blue spring,anybody have any ideas on getting the initial start to srtay down, i am going to try some weight in the heel and see
Buckeye
- Lakes Region, NH
89A10
Put 4.5 in the heel and try that. I played with these weights last year and found them a little too light, even fully loaded for my shorty. You may be able to use them with the long track though. They are an excellent weight. I used to use them in my V-Max 4.
I intend to try them with my turbo now that I can use 4 at a time. They are a very good all around weight.
ExTrEeMF7
YOU CAN
aslo weld some weight to them in the tip or all over and weight them to be the same
some times a guy has to make hes own weights and can get a hell of a good set up
Turk
Tech Advisor
You can go to a primary spring with less preload or add weight to the 1st hole or run a helix with a higher start angle.
1xr
I'm useing 89a almost the same as the 89a-10 just one rivet hole. I had to weld 5 grams to the hallowed underside of the ramp to give it enough force to reduce belt slip. The totall weight with 4.5 gram pin filed slightly is 57 grams. They work very well compared to the poor stock ramp.
picked192
- Jun 14, 2003
with bad tracction you are going to over rev,use a gr/sil/gr prim spring and maybe load up the inside hole.
as i mentioned last week we used a very steep angle and ran about 10000 to 10300
rxwhopper
i tried the 53-46 helix with the silver spring and it wouldnt pull more than9500 rpm,i think the spinnin there shifted in in to much, with pickes it might not shift out as quick and maybe hold a good shift rpm, not done trying yet
