yamagone
- Dec 17, 2008
- Essex, Ont. Canada.
- 18' Sidewinder
Are there any benefits to switching to an 8DN with all stock clutching on a 15' ltx?
Thanks, Coop.
Thanks, Coop.
skidooslayer687
- Aug 22, 2013
- Almonte, Ont.
- 2014 Yamaha Sr Viper LTX SE
When I switched from the 8jp to the 8dn I noticed that the 8dn was more consistsnt with rpm numbers
rbell14
Don't you need to make some adjustment when switching to 8DN. I did not think you could just throw it on and go.
skidooslayer687
- Aug 22, 2013
- Almonte, Ont.
you need to add shims to the back of the secondary to compensate for the longer belt
yamagone
- Dec 17, 2008
- 18' Sidewinder
Is it worth doing by itself with no other clutching changes? What would be the benefit if any?you need to add shims to the back of the secondary to compensate for the longer belt
skidooslayer687
- Aug 22, 2013
- Almonte, Ont.
It gave me more consistant rpm readings which allowed me to clutch the sled a lot better... From what I experienced with the 8jp belt I was getting different rpm readings each pass back to back, threw the 8dn on and that was gone... To answer your question I would personally, not sure if your going to see a gain or anything but it may make it more consistant and allow you to clutch properly... There has been others on here that run he 8jp belt with no issues at all and love there machines, and others have had the exact problem that I did
stingray719
Stock belt for a lot of us slips and filled clutches with belt dust causing odd shift issues. Lots of info here - http://www.ty4stroke.com/threads/losing-rpm-and-not-holding-normal-top-speed.126678/
09nytro
Why not try a ultimax xs825 belt ... Very little belt dust and grips very well and same length as 8jp ......just put on and go ......
More consistent rpm, cheaper, cleaner and lasts longer
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
Or the gates g force even cheaper than the xs, I have been running the gates for 2 seasons with good results and the gates 8jp version. Yamaha's belts are long lasting but to hard and are not as grippy as a good aftermarket belt.
csederlund
- Oct 7, 2012
- Frederic, WI
- 2014 LTX SE
So which is better, the Gates or XS825?
Nytro40th
- Sep 19, 2007
There both good belts I have ran them both. Depending on where you purchase the gates may be cheaper.
csederlund
- Oct 7, 2012
- Frederic, WI
- 2014 LTX SE
Dennis Kirk sells the Gates $35 less than Ultimate.
09nytro
Both are good belts , consistent rpms , lest belt dust and cheaper than a Yamaha belt .....yamaha belts are to hard ....
I've run XS belts on everything I have owned , so I would go with one of those
skidooslayer687
- Aug 22, 2013
- Almonte, Ont.
I've ran 8dns on everything I owned, never have blown a belt, no issues and always pull hard... Buddy ran a xs on his doo, and we were stopped on a rail bed pulling belt strands out for 45 min.... They may be hard and a little pricier but they last, and a lot more consistsant than the 8jp belt... To each there own, just stating what I've found from having a heavily modded srx, 2 stroke viper, and maintaining buddies nytro... Always have ran the Yamaha belts
