I have seen some threads saying Yamaha makes the SMA-8FP38-01-BK but I can't find an application for it from Yamaha. The 8ET-47310's are a much heavier wheel than the outside bogie wheels are even though
they are the same size and take the same bearing (6005) . The wheel is used on virtually every Yamaha sled being made so I am hoping to go with a replaceable bearing model.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Re: 8ET-47310-00-00 Heavier track wheels
Not quite understanding your question RR but if your referring to the new Yamaha spoked wheels with replacable bearings, then those came out in 2010.
I purchased some for my 08 Vector and they have been problem free so far, and it is a nice feature being able to regrease the bearings or replace them altogether without having to replace the whole wheel
(Sorry, no part numbers, I just asked for the new spoked wheels in red when I ordered them)
Roadrider said:I have seen some threads saying Yamaha makes the SMA-8FP38-01-BK but I can't find an application for it from Yamaha. The 8ET-47310's are a much heavier wheel than the outside bogie wheels are even though
On the Phazer Mtn they sit right at the fulcrum for the
front shock to rear shock linkage. Your skid actually
had all six of the heavier wheels so I guess they will
be fine. How many miles have you put on them?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Roadrider said:On the Phazer Mtn they sit right at the fulcrum for the
I have less than 2,000 km's but no issues so far and they still look in great/new shape.
You could ask anyone with a 2010 or up model with a lot more miles though just to be sure?
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
SMA-8FP38-01-BK = 130MM. 6005 bearing included, (sold individually) (does not fit 2010 Apex & Vector GT & LTX, or any models with Mono Shock 2 rear suspensions or VK540) $22.95 This info is from the Accessories catalog. I have 6 of these wheels I can sell you with 500 miles on them in Red.
The Phazer is blue. Just ordered two in silver. I am not sure why Yamaha doesn't list them
as a replacement for the Phazer 8ET's I hope they will
work ok. Irv above has them on his mono-shock and
says they are fine. It may be a tracking problem with the track or the rubber is not as thick in height as the 8ET's and the plastic could contact the drivers. We'll see. I am really surprised no one has a definite answer including the dealers I called.
Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
FYI,
I have replaced two bearings and the wheels are still in good shape on my 2010 apex LTX GT with 5100 miles.
I have replaced two bearings and the wheels are still in good shape on my 2010 apex LTX GT with 5100 miles.Similar threads
