Yammi-Rider
Hi guys, what effect will I see going from 9 tooth to 8 tooth drivers if keeping everything else the same? I'm thinking I will see Top end reduction and more low end torque....is this correct?
radianguy
- Jan 1, 2007
It is essentially the same as gearing down in the chain case, not sure how much change you will see though?
radianguy
- Jan 1, 2007
Just found this in a search...you dropped your gearing 12%. Are you going to gear up to accommodate?
Yammi-Rider
I guess I will run it and see how I like it......top end is not an issue for me but having more low end torque is something I would love to have....especially with the upgraded track.......my guess I will leave it, but I will have to run it first before I make any decision on gearing changes.
radianguy
- Jan 1, 2007
She's gonna pull stumps with that set up!
Yammi-Rider
radianguy said:She's gonna pull stumps with that set up!
That's the idea.....we'll see
