Auskins
any of u guys run 96 studs on your warriors or is 96 just for the 121s
if so what patter do u use
i just so happen to have won 96 FAST-TRAC studs on snowgoercanda.com/forum
and that contest is still on the go...one winner per week until christmas time and there only 200 odd members so the chances are pretty good for u 2 win 96 carbide studs and backer plates and the tools 2 put them on with so u guys should go sign up
thax
thax
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
96 is for the 121 inchers, 2 per row.
108 for the warrior. I recommend in a V pattern up the middle.
Auskins
would a patter of 90 studs in a V-shap like...
o
o o
o o
be just as good because i do not see any way on there web site to buy separt studs
o
o o
o o
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
You probably could. But why not just order another bag that way you can have extra's should you ever need them. Or you can do Like I did and install 126 which is a pattern of 2, 2, 3. I placed a 3rd stud in every third row in the middle of the farthest studs.
LazyBastard
Call dealers until you find one who sells studs by the each. Don't worry about getting the same kind, just be sure to get the same length.
