sgilbert
since I cant access the 2 stroke forum and this one is way better. anyone with knowledge of this? these angled bowls have confused me before. I assume that with carbs 45 upsidown, the floats should be parallel to the gasket surface. this one was adjusted to be pependicular to the slide, which also had a fair bend in the tang. in my experience the tang is generally flat if set up right from factory.
