a couple of questions (VectorER)
srx600
Upstate NY
Can you recharge the battery by using the jumper leads?
The track is racheting just need tightening?
Charging the battery via leads should be no problem. I have done this myself. Use a 2 Amp charge with auto shut off and if possible use a microprocessor controlled charger as they perform very well.
Adjust your track to spec. I have mine set at spec and have no ratcheting.
What Flipper says.
Those are made specifically for jumping. That white plug that is right there by them is specifically for the Optimate charger that Yamie dealers sell.
Fantastic charger and worth every penny of the $50
questions
My Vector track was ratcheting just a little, and I checked the tension yesterday and indeed it was loose. Fine dealer setup mine got.
Tork, some of your pictures kill me!
