Redcandy05
The cost is about the same to go either way. I was wondering what some of your thoughts are. either way, pro's, con's, preferences, ect.
redliner
Ever ride a turbo? All it takes is one ride on one and that will make your decision. I would go w/ the turbo!!
Redcandy05
Never rode a turbo sled. I have owned a number of turbo bikes (GPZ 750, seca 650, honda cbx). Like the idea of 2 boost settings.
Otis RX
I've been in sleds for 30+ years and have always been cautious about add on mods.
I've seen the claims and most are crap and cause more problems then they're worth.
Not with the turbos. I have the Bender stage II and installed it myself. If you have a little knowledge and common sense you can too.
If you have someone else do it then your asking for issues. You need to get intimate with it like a fine lady! You need to be able to work on the turbo and clutching for your riding application and conditions. Not a lot of maintainence, just knowledge of how things work. Like any other sled. If you like tinkering then you'll love it.
The power is "un -f'n - believable!! No stock, or even close to stock, will touch it. Believe it!! The only thing that might get close is a 1400 Hooper.
No MACH -Z , no F7, No T-cat.
Once you ride it you're hooked.
Best thing I ever did.
Again, it all depends on what you're doing with it.
I set mine so I can ride trials or kick major butt on the lake . And it does just that!
OTIS
OTIS
impalapower
Even if you don't get a turbo, I'd ride the sled a bit more, your depreciation is a big hit on the first year.
Get a cpr turbo!
SoCoRX1
i was torn between a new Apex Mtn or a turbo/supercharger for my sled. im getting the turbo or blower. the new engine is only 150hp.... the turbo is 200+ hp. the apex will still lose plenty of races. the turbo'd sled wont lose many, if any.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Once you ride a turbo you will never go back to an sled with under 200hp. guarenteed.
SuperTurbo
- Mar 20, 2004
- Amherst, Ohio
- 17 LTXse Sidewinder
Redcandy05
Brands, front rear? What to choose? We do mostly aggressive trail riding in the UP. Average about 200 miles in a run.
if all you want to do is trail ride buy a new sled. If you like tinkering and don't mind paying close attention to your turbo then get a turbo.
- Sauk Prairie, WI
- www.ty4stroke.com
I have an 03 with about every mod you can do including a CPR turbo. The sled is insane and very fun to ride. That said, I rode the new 06s yesterday and they for me are going to be hard to pass up. They are just fantastic...BBY
Redcandy05
Don't mind tinkering, have a 68 Chevelle that is a complete rsto. But don't want to spend a ton of time tinkering either. being a mechanical engineer, I am acussed of tinkering too much
. lol
. lolSimilar threads
