mnmsnowbeast,
Yes he can add the clicker to the stock sogi yammi shock. Yes you still have the use of the dial that currently runs the sogi shock now (rebound adjustment). Yes you would have the ability to adjust both rebound and compression on the stock shock (sounds pretty slick to me). He told me that I could get a used Fox clicker from an old shock for close to nothing or I could buy a new one from Fox for about $150.00. So for a maximum price of $200 (using a new Fox Clicker) you could have, in my opinion, a better set-up then the Ohlins electronic shock that costs $935. He charged $50 for the re-valve (very reasonable price). I'm not sure if he changed the valve stack. I told him that the shock was bottoming out and he told me it needed to be slowed down starting about 3/4 of the way through the travel. I can check with him to find out exactly what changes he made.
