Vmax4
- Apr 18, 2003
- Orondo, WA
- 2010 FXNytro MTX 162 SE with a 270 hp MCX Turbo and assorted goodies! - 2018 Sidewinder M-TX SE 162 with an EVO 260 hp Tune, - 2021 Mountain Max 154 LE - Various Yamaha Sleds Back to a 1968 SL350
So, I want to add a cat magnetic tether to my 2018 Sidewinder M-TX SE 162. I have searched and read a bunch, looks like there is no plug and play option? Any harness part numbers, tether part numbers? DIY Fixes? Sled is new to me.
idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
A quick look at the parts fiche shows prt#'s...
8MS-H6284-00-00 --Stop switch
8MS-H2552-00-00 --Switch cap
8MS-H4395-00-00 --Retaining ring
Vmax4
- Apr 18, 2003
- Orondo, WA
That’s not the magnetic one?
idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
DuraPro Magnetic Tether™
Engineered to be the most dependable, most durable, highest performing, easiest to install, and easiest to use engine cut-off tether on the market ...
Vmax4
- Apr 18, 2003
- Orondo, WA
I would like to use the Cat one, so both my Mtn Max and my Sigewinder have the same switch. My son and I can trade on the limb and leave tethers attached to us. Was hoping there was a cool wiring harness pigtail I could buy and plug and play one!![]()
Engineered to be the most dependable, most durable, highest performing, easiest to install, and easiest to use engine cut-off tether on the market ...www.duraprousa.com
idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
The parts I posted above are for the stock Yamaha magnetic tether. Magnetic switch but mechanical connection. The tether snaps over the switch. Arctic cat tether is the same. I'll post a link to the cat tether.
idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
Not sure if you know about this site, but you can upload a picture of a connector and it will tell you what it is.
findpigtails.com
Shop Automotive Connectors
Discover a wide range of automotive connectors, pigtails, and plugs at findpigtails.com. Lightning-fast search, helpful tools, and how-to repair guides available. Trusted by dealerships and insurance.
MK4TDI
- Jan 29, 2020
- Lloydminster Area SK,
- 2014 Summit XMX 800 154
2015 Summit XMX 800 146
2017 Sidewinder MTX162
If you go the Cat route, they have 2 listings, one for the 2 stroke and one fore the 4 stroke, make sure to get the 4 stroke.
I installed one on my 2017, I dont recall it being that difficult, but that's getting to be a few years ago now. I'll see if I can find some wiring drawings for it.
