Adding oil pressure gauge to my RX1
Ron's
Canada
2008 Yamaha Vector LTX
I'm trying to find out if anyone has ever added an Oil PSI gauge to a RX1 as I don't much trust idiot lights. Any help would be appreciated!
Oooooooo I like the idea of gauge! if you find out how please update us
Hmm not bad idea but all the bouncing around a sled does if the plastic line rubbs threw or breaks poof there goes ur oil aftermarket gauge is gonna be a a mechincal gauge would think u could just t into the tank return line line and get ur reading there use brass t and hose barbs
If it's possible would probably go with totally electric gauge to iliminate possibility of oil line being rubbed through. If I can find an oil gallery on the engine I will try it out.
The oil cooler adapter has a big bolt on it right beside the filter. I drilled and tapped that bolt for A 90 degree an fitting and used a small Autometer mechanical gauge in the old ignition switch as I moved the ignition to the other side. Braided line that I used wouldn't wear thru. I used P# 2180 autometer. You could use an electric one as well but I wanted the simplicity and reliability of a mechanical gauge
Thanks man I will look into that. I love gauges instead of idiot lights.
