snowbelt
- Mar 15, 2005
I'm thinking of adding a rear cooler to my GT for added insurance. I heard of one for the rx-1s. Does anyone know if this will fit on an Apex? I think the part # is 8ET-RHECR-KT? Price is supposed to be $85. Any one have a pic of one installed on an RX-1?
stinx
I had one on my Warrior it worked very well. I dont think you will need one with the Apex because of the Combination heat exchngers and small radiator and cooling fan.
richierich
- Apr 23, 2003
- Greenville,WI
- 08 Apex LTX
I dont think its needed either.I ran alot of low snow conditions at high speeds with no issue.
snowbelt
- Mar 15, 2005
I still want one. Anyone?
apexer06
I ran last week on hardpack snow and my red light came on twice. I spent more than reasonable time putting snow on the running boards to cool off the engine. As the day went on and the trails got loose, it was not a problen like it was earlier in the day. I have been reading today that Yamaha has been putting 100% antifreeze in the Apex's. I will have to check this when I get a tester. My Warrior had issues the two seasons I had it with the red light coming on. The heat exchangers under the running boards don't do a great job, I always had warm running motors with my Polaris.
trlbrkr
I am having trouble with overheating riding with the children on their sleds at speeds around 15 to 20mph on tight trails with hills on my attak . I was able to cool it off filling my running bords with snow but that only lasts about 5 miles...
wavey
I also had the warning light come on my attak several times on my 1st ride, especially at slower speeds. I checked to make sure the fan was running too. I am going to check the coolant mixture and rebleed the system and try again. The conditions I rode in would not have been a problem for my 05 rx1.
welterracer
You dont need a rear cooler.. Drain the antifreeze and replace with WATTER WETTER and a 50/50 mix of antifreeze and watter!
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Make sure you run the antifreeze that is recommended by Yamaha otherwise you'll start seeing rubber chunks in your overflow bottle...
