Adding temp gauge??
chevyfreak
NE Iowa
I am looking at putting a temp gauge on my sled and wondering what hose i should be splicing into for the T? Thanks
hose
I put mine in the hose in back of the rad that runs up to the left hand side of the rad. Be sure to use pipe tape when you thread the sensor in. Also when you cut into the hose be sure to have some absorbant rags under as you will lose some coolant. If you get any on the motor it will smell and steam until it burns off and you will get paranoid you have a leak!
