Acedog1
Hey guys,
I have a 07 Apex RTX stretched to 128" runing a Cobra 1.352 track and am planning to run 1.450 Woodys Gold Digger studs (204 qty.). Do I need to add more material to the existing tunnel protectors? If so how much? 3/8, 1/2" etc.
Thanks!
Thanks!
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
I think you do. I don't know how much as I have an Attak. But with my Attak I had to go almost 1 1/2" over the cooler tapering down to nothing just behind the upper wheels.
Lot's of posts here so a good search might give you the answers for the exact amount of inches.
sherlock29
I would... My stock RTX with 168 1.325 woodies still kissed the exhaust/tunnel. Only a real issue at high speed bumps when track is ballooning... I'd go another 1/2" if you need anymore than that you have other issues!...
Acedog1
I'll add some HPDE in 1/2" thickness the length of the current tunnel protectors and see if that is sufficient. I've searched all over trying to find out but there are so many variables!!
I weigh 160lbs fully dressed so hopefully that is in my favor!
Thanks!
I weigh 160lbs fully dressed so hopefully that is in my favor!Thanks!
CaptCaper
- Jan 1, 2007
- Northern N.H.
- New Hampshire
On my Attak I was told not to go past the upper wheels and to end before them coming from rear because the track will bind in there but this was for an Attak I believe.
Acedog1
Anybody else have 1.450 studs and additional protectors??
