gilly67
i need to adjust the steering on my 07 phazer. when the skis are straight the handle bars are turned to the left a couple of inches.anyone know how to adjust or should i take it to the dealer. I have to believe you guys know more than my dealer
Gilly
Gilly
sniperviper
Have it been out of adjustment the whole time or have you hit something hard? Have been issues with bent spindles....
Check this out: http://www.ty4stroke.com/viewtopic.php?t=37357
Its easy to fix if its only need to be adjusted but my english is not so good and I have problems to tell you how to do it in english but I bet someone else here can help you out.
gilly67
my nephew hit a tree head on at about 35mph
Yellowknife
if the ski's are both straight, then you need to adjust the tie rod that sits along the side of the sled above the engine. You need to remove the airbox to get at it, then it's easy. Loosen the nuts, twist the tie rod until your steering is corrected, and retighten the nuts. That's it. Removing the airbox is easy too. 3 allen bolts, and disconnect all the hoses and electronics that plug into the airbox. That's it.
gilly67
thank you for the info i thought that is what i do but wasnt sure. i already check the skis and they are fine so i will make the adjustment and see how it goes thanks again
Gilly
Gilly
- 8K
