Crzy4Snow
Took the first ride on my RS Venture and loved the ride but I need a little more ski pressure. (pushes in the corners a little to much for my likeing). My first thaught was to set the preload on the rear springs one setting stiffer and then set the middle spring one setting softer but not sure if its is right. I know being a long track it will push more in the corners but the trail conditions were very good and I am a little worried what will happen in icy corners. Thanks Trevor
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
Try one change at a time.
I would either reduce the preload of the center shock or increase the preload of the front ski springs. Either one will give more ski pressure.
If the push is more of a problem under acceleration only then you might want to reduce the weight transfer.
