Turk
Tech Advisor
Troops
Here are some advant-edge helix code #,s for you. These are on the non-roller billet helix,s only
51/47=4
48/40=3
51/37=6
Straight 51=11
53/47=8
50/44=5
51/43=10
Thi is all I have for now.
51/47=4
48/40=3
51/37=6
Straight 51=11
53/47=8
50/44=5
51/43=10
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Turk, I purchased a 49/43 and it says it's a 4. Can you double check your 51/47?
Turk
Tech Advisor
#4 is a 51/47; had 2 of em & they both said the same code.I can,t vouch for the code #,s but both 51/47,s I had were stamped with a #4.There might have been a change in the #,s but does it say 49/43 or #4 or both?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Turk, some of your codes are incorrect. Your #4 would be one of them.
Turk
Tech Advisor
Could be; I am just reading the #,s stamped on the helix beside the codes. This is just what was on my personal helix,s & trying to help guys identify helix,s Sorry for any discrepencies.
- Apr 17, 2003
- Menno, SD
- Menno, SD
No problem Turk, I have seen helixes stamped with the wrong number. It does happen occasionally!
BADSLED
- May 13, 2004
- Syracuse, NY
my 49/43 (engraved) has a 4 stamped on it ..
