Aftermarket intake valves
venturemax
brampton ontario can
I was just doing a t-up on my 03 rx1( MCX ,15lbs,Wiesco low comps,14000 brutal Kms on set up)and i have to adjust the intake clearance again because of zero valve lash. The intake valves on these motors seem to be really soft, even non turbo motors require constant valve adjustrments if you really like to hang on to the paddle for extended periods of time. Does anyone know of an aftermarket stainless valve that is available. Thx
Thanks Lakrcr. Further investigation has led to Kibblewite Machining, Seems that the R1 stainless valve and spring kits are the same. The less expensive spring kit (no retainers) is recommended for turbo applications. Its snowing outside, i have to go stand in it seeya.
