air flow to intercooler
powershot1
SHELBY TWP MI
I've been working on air flow thru the intercooler.I've added a scoop to the hood .and foam to the bottom of the scoop to direct air through the intercooler.I also added foam to the clutch side to keep snow from getting on the clutch.
I also found in testing that you must roll or concave the back edge of the foam to direct the air into the intercooler. a square edge does not work.
I must have 10 hours into this project I have also installed thermal coupler into the heat exchanger so I can see the Delta across the cooler.
scoop
I have been running a scoop like that for 3 years now and it works good.
My scoop
Here are some photos of my set up....I really like the graphics on your sled.....
scoop
I would like to see it when its done and on the sled.
photos
I will try this one more time......) Where did you get those graphics? I am supposed to get a wrap kit from my bride for Christmas..
