Newfie Apex
- Mar 3, 2010
- Mt. Pearl Newfoundland
- 2008 Nytro
I have an '06 Apex rtx and am wondering what most people are running the air pressure in the shocks at...Mine were at 70psi wondering if I should go higher or lower..
ahicks
I think most would agree that you would use whatever it takes to level the a-frames? Pressures normally adjusted/measured with no weight on front end.
greenmntpass
- Jan 7, 2005
- Middlebury, Vermont
- 2000 SRX
My '06 RTX a-arms level, 45 to 50 psi like ahicks said. Air pressure set with no weight on front end.
slow x 2
air
my 06 rtx is set at 45 to 50 psi and so far it works the best.
Liquid Blue
I've got an '07 RTX with the 13mm sway bar. I run 62 lbs. Lower front end handles great and still can attack the moguls.
75lbs for me and not changing.
ScottyD
- Mar 2, 2008
i have a 13mm swaybar in mine and run 45psi, works good
