AIR SHOCKS ON REAR SKID 121.....?
yukon yamaha
WHITEHORSE, YUKON CANADA
Canada
2008 nytro custom! 2014 viper custom
has anyone tryed or even entertained the idea of putting fox evo's or "X's" into the rear skid of a 121 rtx? I have seen the new mtx machines and the weight they lost this year and that many pounds lost on a short track would be epic!..... i have been playing with the idea for a while, but i cant seem to find the right length shocks and i am not famillier enough with fox shocks to know what they have that would work.....
any help and all input is welcome please!
i think that it could work but looking at the suspension i might have to change the shock mount abit. I dont know if they would be stronge enough to do the job of the springs and shocks and not break the mounts
I dunno about this i know fox floats are one of the best pair of shocks you can buy for a quad. For you quad riders i'm also saying better then Custom Axis and Elka. But just the weight of the snowmobile and the rough terrain I don't know if they will be able to handle it. You can only put so much PSI in a canister such as a shock. But i could be wrong.
The idea is interesting and one should really check what it takes to get them into the rear skid. In contrast to the front end, I could think about couple of possible advantages offered by the quite extreme progression of the air springs...
yeah i think the hardest part will be not the length of the shock but how it reacts with the front shocks, i figure if the shocks on the new mtx can handle the length of a 152 + a more vertical shock position on a 121 should be easy enough, i am trying to make this work i have a few parts of a wreck sled and i will post picts when i get the parts back from the shop
Just from looking at pictures, it does not look impossible.
Shock absorber total length as well as stroke seem to be fairly close.
Then, calibrating a rough trail sled and a mountain sled is two completely different things...
I don't think the calibration would be too big a deal. The valve stacks should end up being very close to what would work in a conventional shock. There's just not that much difference once inside of a Float. Compression may be a little different, but that shouldn't be very difficult to work around.
The really early (90?) Poo Edge suspension used a rear coil over, and I don't remember reading much in the way of structure failures at either end of that setup (nearly identical to this one) - though that would be one of my main concerns.
The biggest concern here, would be to come up with a shock that might fit....
yes, i would have liked to have a res on both front and rear shock in the skid, so it will be another hurdle to cross to make sure it wont rub or hit the other shock but i think it can be done! i do think that the suspension will be super stiff and that is what i am looking for and it will rock for boosted sleds!
