nitromator
I have an 09 Nytro MTX 153. Wondering if anyone has installed the Airframe running boards on this tunnel? Do they fit well? Are they stiff or does the tunnel flex when riding? Does the tunnel behind the running board need to be tapered like the stock 2010 - 13's? Does it need to be reinforced?
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
nitromator said:I have an 09 Nytro MTX 153. Wondering if anyone has installed the Airframe running boards on this tunnel? Yes alot of people have Do they fit well? they fit very well and look nice Are they stiff or does the tunnel flex when riding? No flexing at all Does the tunnel behind the running board need to be tapered like the stock 2010 - 13's? the 08-09 mxt has a different tunnel taper so if you were to buy the 2010-2013 boards yes, but they do make 08-09 boards as well (at least they used to) that you wouldnt need to change the taper. Does it need to be reinforced? all of the instructions are in the kit
