DaveRX1
I had my skid out for a track change. I did not notice until I went to reinstall the skid but then I noticed the inner portion of the "w" was cracked allmost all the way through where the cross brace that the limiter straps run up and over. I pulled the W out and rewelded all of the welds that were cracking with three passes of 1/16" rod @55amps. I feel that it is now stronger than it was before. If you rid hard and have 2500 miles or more on your sled PULL OUT THAT SKID AND TAKE A REALY CLOSE LOOK AT THE W ARM before it breaks!!! I am sure that my arm would have failed completely if I had not discovered the cracking (and soon!!)
You can be sure that I will be keeping a close eye on my W arm!!! :shock:
