krauss2005
i have an 03 rx-1 long track 151, it skips the drive sprockets when it hooks. how much are the anti ratchet drivers and how much of a pain r they to install? i also hear ppl have trouble with them. do the short tracks have a problem with skipping also? wheres the best place to get them?
JDMCRX
We have 121 and a 136 and ive set the track to yamaha specs on the warrior and with the new clutch and a hard packed i rachet so bad it shakes my head.
Bump
Bump
04yamaharx-1
I've got the same problem with my 04 RX-1 with the Hauck GYT-R-Dun kit, I was racing a 800H.O. trying to really get on it and my track was ratcheting like crazy. I have really been contemplating buying a fully clipped rip saw so i can put in anti ratchet drivers for this year to get rid of that problem but i'm not sure i really want to do it if its gonna be a pain to install. I too would like to hear some responses about people that have done this on a 121
Red2003
Count me in. The only way to stop the ratcheting is to run your track tight as a bow string and/or take all of the weight ttransfer out of the skid. I believe several guys here have gone the anti ratchet driver setup. I recall a need to have them turned down a little before installing becase they rubbed on the w-arm or front shock mount or something??? I'm gonna tough it out one more season, but next year I need to do a track swap anyway, so while I am there with everything torn apart, she's gonna get anti ratchets. They are quite pricey, and you gotta take the whole chaincase apart to get out the drive shaft, so its quite an ordeal especially with reverse. You'll also need a press to install them.
4bangdan
- Sep 8, 2005
- Fort Kent, Maine
- 2004 yamaha rx1 2015 yamaha apex xtx
also, you need to have a track with all windows open. you might want to check that before ordering.
Jack_Shaft
Anti atchets make so much sense on these high torque sleds.
Go for the Ski-doo extroverts, they fit right on there, they use a harder compound than the aftermarket companies and they're DIRT cheap.
I have posted the P/N's in this forum and in the turbo/supercharger forum, just do a search. FYI the RX-1 and Warrior use 9T drivers, the Mtn uses 8T drivers.
Personally, I run Kinetic 9T drivers, but I came across them for cheaps and jumped on it.
JDMCRX
Nice ill have to look for that post.
JDMCRX
Ive search few of ur post which post was it in ur 1.5" track install?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
I long-tracked my Nytro with a 136" x 1.5" track. I also installed the Ski-Doo intro/extro drivers. Very nice drivers!!!
Red2003
gade-thrasher said:I long-tracked my Nytro with a 136" x 1.5" track. I also installed the Ski-Doo intro/extro drivers. Very nice drivers!!!
How much $$$ ? and do you have part numbers? Thanks!
Red2003
BWT, why the hell don't the higher HP sleds come through with them??? I'd think it would be cheaper for them to produce 2 pieces of plastic vs 4 anyway, and it would actually work. ????? Cheaper tracks, maybe?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
Red2003 said:gade-thrasher said:I long-tracked my Nytro with a 136" x 1.5" track. I also installed the Ski-Doo intro/extro drivers. Very nice drivers!!!
The driver part numbers are listed in the turbo/supercharger section:
http://www.ty4stroke.com/viewtopic.php?t=28246
You can get the drivers from any Doo dealer. I bought mine from Ingles Performance. I've bought some stuff from them before when I used to have a Doo. They've got the best price I've seen for these drivers. About $40 each.
http://www.inglesperformance.com/default.asp
Jack_Shaft
Red2003 said:BWT, why the hell don't the higher HP sleds come through with them??? I'd think it would be cheaper for them to produce 2 pieces of plastic vs 4 anyway, and it would actually work. ????? Cheaper tracks, maybe?
Good question.
Honestly, it appears that it's because of track noise and the fact that tracks may not last *quite* as long when using extroverts due to the additional stress put on the rods they have to drive against.
Sounds odd, but it's quite possible. The increased track noise is noticable, believe it or not.
DC5
Extroverts slow down top speed
Red2003
Jack_Shaft said:Red2003 said:BWT, why the hell don't the higher HP sleds come through with them??? I'd think it would be cheaper for them to produce 2 pieces of plastic vs 4 anyway, and it would actually work. ????? Cheaper tracks, maybe?
Good question.
I guess that makes sense. I bet they aren't as loud as when my track ratchets though. lol BTW, why would they affect top speed any??
