bitchnblue09
Has anyone put, or is it ok to put Anti-seez on the bushings in the A-arms?? Or would it be better to put greese in there when installing them? Thanks
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
If they are oil lite bushings, don't put anything on them. If they are the factory plastic ones, use a good quality grease. Anti-Seize isn't really much of a lubricant, more of an anti-corrosion compound.
LSXM3
Use a waterproof low temp grease designed for use in the snow on them. Some people have even added grease zerks to their arms so they can pump additional grease in once and awhile!
mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
Drill holes in a-arms and install zerk fittings so you can grease it and the plasic oem ones will probably last forever
