UP bushman
Does anybody have any ideas or success on increasing track speed on your Mountain Lite.
well your climbing?
Exhaust,filter kit,etc.If your into doing alot of climbing you could gear down.
Turk
Tech Advisor
Gear down & also make sure u have a slight overrev at full throttle just below rev limiter.
rideblue
- Mar 17, 2005
- Buena Vista Colorado
- www.mountaintechbv.com
Boost !?!?!?!?!?
ewg95
- Oct 30, 2007
Track Speed
Gear up actually 19 tooth top gear. I tried to gear mine down last year but found my track speed about 10km slower. The phazer makes a #*$&@ load of low end so when gearing it up you will lose bottom end but it has a ton to spare and you'll gain about 10k on top. Pipe it as well, I found a stock 94 ZX6R exhaust and the pipes are the exact diameter. Then put a couple of holes in the air box. I've managed to scrape out about 110 or so on the track top speed.
powder muncher
Your gonna hate me for this-------its called a turbo!!!!!
UP bushman
That's ok powder muncher it's not that important. More power is not always everything.
yel_low
8" billet wheels?
and.. Turbo
and.. Turbo
- 11K
