first time i used my new electric shield. started to melt around the edges. now it's wrinkled messed up. any ideas? i'll be taking it back tomorrow but just wanted to see if anyone has seen this.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Did you peel off the plastic protectors? There is also one on the inside.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
i've fried the cords, never the shield. i did have one that was on a cheap helmet that would melt snow, ice and freezing rain it was so hot - the higher end ones i'm running now are not as hot.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Sounds like you just got a defective unit...what brand?
only had the protective film on the outside. wires run around the inside edge. it's a CKX.
woolyviper
- Mar 24, 2006
- hibbing,mn
i run a ckx - mine doesn't get hot enough to melt butter, but it doesn't fog up either.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
snowrdr said:only had the protective film on the outside. wires run around the inside edge. it's a CKX.
Check it again. All the CKX heated shields I have seen have the protective film on both sides. It is hard to see. If the shield is not perfectly clear, it is there.
Sheilds will warp while connected while sled not moving. This will happen if your connection is one of those "direct to the battery" and that you leave helmet connected on sled while you go dine.
Could be you case ?
Could be you case ?
i have it plugged into the 12v outlet so if the sled isn't running it's not on.
