Anyone hook a VDO or Racepak up to their RX-1?
Srxspec
Ulmer Racing
Tech Advisor
Menno, SD
Website
www.ulmerracing.com
2014 Yamaha SR Viper LTX, 2014 Yamaha SR Viper RTX SE, 2015 Yamaha SR Viper MTX SE 162 (turbo), 2015 Yamaha SR Viper MTX SE 153
LOCATION
Menno, SD
WEBSITE
www.ulmerracing.com
Hey everyone, was wondering if anyone has hooked a VDO tach up to their rx-1 and if so which wire you picked the signal up from & which dip switch settings you had to use.
Also was wondering if anyone has setup a Racepak on their RX-1 and which wire you tapped into & which setting you had for pulses.
Thanks!
I have the Racepak Hot Tach Pro. My sled is in Storage, but I can stop by tomorrow and start it and check the pulse setting. I don't think I wrote it in the directions, but I'll check. I know Phil has the Racepak on his. I'm sure the pulse settings would be the same for all the gauges.
I plan to hook up a Hot Tach Pro as well using the engine rpm & jackshaft rpm inputs. Which wire did you tie into for the engine rpm? Thanks
I guess I should have checked the forum before I went over to the storage unit. Oh well, the pulse setting is P 6. As for the wire?? That will require another trip :o| Good thing it is only 2 miles away.
Looking at the schematic it should be Y/B or Yellow Black, but I will have to check to confirm. Another thing, on the Hot Tach Pro the rpm's are perfect until 10,000 and then they become erratic. There was a post on here months back about having to send the unit back to EGT to reprogram it to work over 10k. When I called them a year ago they didn't really have an answer for me. Maybe they have figured it out and have a solution. It may have been Lakeracer who made the post. I wish I could remember. Anyway I'll check the wiring and let you know.
Buckeye, thanks for the info! I think you're right with tapping into the YB wire. That's what I was going to tie into by going off the schematic. As far as the HTP reading past 10,000 rpm I have had no problems with that. I've had it on a race Viper that runs 10,100-10,250 rpm and it works fine :-o I did have to put a resistor in the line though. I've had it all the way up to 11,000 rpm with no problems. Thanks for the help!
