TonyVT
Just wondering if these plugs work ok. Splitfire SF406B Spark Plug
The price is right at Dennis Kirk??
comments???
tony.....
comments???
tony.....
SUPERTUNER
Re: Anyone run Splitfire SF406B Spark Plugs?? In Rx or other
I can't say that I have run them in an RX1, but I did build a Kawasaki dragbike for a customer back in 1998 that installed them without telling me. This bike ran like 8.50's and was running real well with the NGK sparkplugs that I installed. He out them Splitfire's in and lost 3 to 4 tenths on his ET! Of course I was being blamed and I asked him to bring the bike back so I could put it on the dyno. The engine produced something like 18 to 20 less HP at the rear wheel. It also made the ignition system break up and the top end rev limiter come in at all different RPM's. Frankly these problems are a sign of increased "spark energy" which is the only thing that would make more power when properly fueled.
I am not bashing the Splitfire sparkplugs, but this was my experience with them. If you test them, let us all know how you like or dislike them.
Freddie Klies
www.easterncycleperf.com
TonyVT said:Just wondering if these plugs work ok. Splitfire SF406B Spark Plug
comments???
tony.....
Freddie Klies
TonyVT
Thanks for the response. Not so sure I want to be a tester...
:ORC
:ORC
Tom-RX1
used them in a XLT they worked well for that .
Tom-RX1
Tom-RX1
nhrxrider
Splitfires are snake-oil. Back not long after they first came out, we did a test when I was in college and tested them in a bench-mounted ignition system, so we could see the sparks. Electricity flows through the path of least resistance, period. What that translates into with any V-type plug is that the spark will jump through the smallest part of the gap. There will never, ever be 2 sparks on 1 plug. The spark will jump across the side of the tip that has the least resistance. And don't think that once that side is fouled that it will start jumping across the other tip, because by then the rest of the plug will be even more fouled. The last part of the plug to get dirty or oil fouled is the tip, because thats the hottest part of the plug and will burn off the oil for a while.
The testing we did confirmed this. We tried around 8 splitfire plugs and every one of them always fired from 1 tip, and the same tip every time. So buying splitfires is a waste of money. I would be more interested in how plaqtimums would work, if they are available for this motor. But honestly, I don't think its an issue. We have some of the best ignition systems made, and good NGK plugs are all that should be required to handle lots of power very reliably.
Jim
Jim
TonyVT
nhrxrider said:Splitfires are snake-oil. Back not long after they first came out, we did a test when I was in college and tested them in a bench-mounted ignition system, so we could see the sparks. Electricity flows through the path of least resistance, period. What that translates into with any V-type plug is that the spark will jump through the smallest part of the gap. There will never, ever be 2 sparks on 1 plug. The spark will jump across the side of the tip that has the least resistance. And don't think that once that side is fouled that it will start jumping across the other tip, because by then the rest of the plug will be even more fouled. The last part of the plug to get dirty or oil fouled is the tip, because thats the hottest part of the plug and will burn off the oil for a while.
Jim
Jim, Thanks for that!! It makes complete sense to me... Everyone needs to know this.
![Tsr :rocks: :rocks:](/styles/default/xenforo/smilies/tsr.gif)
Tony....
If you are looking for improved performance the NGK CR10EK plugs show gains on the dyno and track speeds. The CR9EK may work well, too.
TonyVT
bjowett said:If you are looking for improved performance the NGK CR10EK plugs show gains on the dyno and track speeds. The CR9EK may work well, too.
Nope just looking to replace them as I have 4k miles. So what would anyone sugest in a STOCK 03 RX shorty???
Thanks Guys....
nhrxrider
Go to the dealer and get 4 more original plugs. They worked well for 4000 miles, use what works. Why experiment? Mine lasted around 5000 miles, and were still working well. i finally replaced them just for good measure. Now I have 4 new ones in my new motor, so I shouldn't have to touch anything for another 4000-5000 miles, except oil changes.
Jim
Jim
.... not an experiment, just a plug that burns a little better than the CR9E. Folks forget that everything on a sled goes through the penny pinchers, even spark plugs. You may see better mileage and longer life from them...
