smokingcrater
So... hopefully last, or second to last, update. Hung them back on, and it runs significantly better! Hooked up my ATF balancer to carbs 3/4 to check those first, almost exact. When I hooked it up to 1/2, #1 promptly sucked all the ATF out of the tube, and promptly did a nice job of fogging that cylinder!
So.. roughly adjusted 1/2 balance by ear and got it at least runnable. It idles/starts/transitions reasonable well. 4 port vacuum syncronizer is on the way, here Friday.
thanks everyone for the suggestions, and hopefully someone else can stumble on this thread at save some time.
Clean your carbs, clean your carbs, and when you think you are done, clean again. (and then balance)
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
Glad it all worked out for ya!
A 4 port sync tool is best, but a two port will have exactly the same end result if done in the right order.
These 4 strokes are super fussy to synchronization at idle.
Has a huge effect on idle quality.
RobX-1
- Coldwater, OH
X2 as it seemed I was always chasing my tails when using just two port. After seeing how all the new Motion Pro sync tools use this new blue stuff, I must have found one of the last mercury ones.
pdiddy
- Oct 12, 2004
- Southern Maine
..but the good stuff is always "hazardous"!X2 as it seemed I was always chasing my tails when using just two port. After seeing how all the new Motion Pro sync tools use this new blue stuff, I must have found one of the last mercury ones.
