morrisond
How did it work out? Does it really help? How strong is it?
GUKROKIT
I've got the pioneer wide front .Made a huge difference on my mountain because of the narrower stock stance plus a 2 inch increase in travel.I had the 38.5 stock went to the 45inch the stability was night and day.Arms are light,strong,good looking,easy to install.only problem was the tabs for the stabilizer were welded on to close together and had to be pried apart to accept the "dogbone" piece.Bruce promised to fix at the end of the season by rewelding or replacement.Also added the 12mm stabilizer and longer links ;no body roll but a slight increase in steering effort was noted.Probably not worth the $ on a shorty because the stance seems wide enough stock.My 2 cents..
