a friend of mine did not start at - 30 celcius he has to heat the oil tank and boost it do you have suggestions thanks...
Tom Lee
There is an inline coolant heater that can be installed. The dealer can do it for you or if prefer you can install it yourself. It plugs into 120 volt ac. Works similar to a vehicles block heater. Drawback: 120 vac has to be available.
MNfarmdude
The secret is to just keep holding the key to start for 5 to 10 seconds.
Don't let off until it is running smoothly. I had the same problem and after
starting it this way, it perfect.
2500 miles of 06 Apex always starts this way.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
I had the same problem, just pin the flipper to the bar and turn the key and hold it till she fire's. I was in -35 weather and the sled sat all night in that temp. and that was the only way it would start. I tried evrything, holing the key on, I didn't want to kill the battery. I even put my charger on it and it still wouldn't fire. Have to hold the gas wide open and crank it.
Vince
Vince
