Apex motor cooling system flow direction
bigdog_mike
Fraser, MI
Using an Apex motor in a side by side and I need to know the cooling flow direction. The service manual only show the parts but no flow direction. I think it comes from the motor outlet then into the water pump and onto the thermostat house bottom then past the thermostat and onto radiator then back to the motor to complete the cooling cycle, if this is correct then the line from the radiator bottom outlet should tee into the hose that comes from the motor before the water pump. Is the correct???
