MT RX1 Mountain Man
Anybody on here running the Hauck GHT-R-DUN kit on the Apex Mountain/MTX? Thoughts?
http://www.hauckpowersportsinc.com/page ... n-kit.aspx
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
HAUCK
Everytime I dealt with Hauck I was not happy !
Always slower than stock !!!!!!!!!
MT RX1 Mountain Man
Thanks gsxr, Kinda like when I tried th RX-1 Mtn with the ECP kit..didn't work so well. Probably just keep it as is....
GotJuice
Hauck
I don't know much about Hauck but I do know that there exhaust increased the RPMS 300 over stock in same conditions with NO other changes on my Apex Mnt. This indicates an increase in power and having to add more weight to primary to bring RPMS back down to 10800. I would assume with the Hauck air filters you'd get more air and with the exhaust you'd have it freer flowing if you add the Power Commander III increasing the fuel curve and ignition timing you'd see a consistent increase across the board. I know Ulmer sells a similar package with the Excell exhaust and can set you up with fuel curves if you buy the PCIII from him, these packages have been dyno proven to increase H.P. around 10 H.P.,
Hope this is helpful some how....cheers!
MT RX1 Mountain Man
Anybody else running this kit?
