I was just wondering how long can I keep the sled tipped up on its side? I don't have anyway of suspending it from the ceiling to change the track and put extrovert drives on it.
Or is this not recommended at all for any time period.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Get a long block of wood(4"x6") with a slot cut in it. Works great. I would not put it on its side.
I have left it on either side for weeks. The oil has always stayed in the tank on mine.
sk-rx1
The only thing I have heard is to lay it oil tank down if possible.
Turk
Tech Advisor
No probs laying the sled on either side if it is not running.
Super Sled
- Feb 25, 2009
- Summit X
sk-rx1 said:The only thing I have heard is to lay it oil tank down if possible.
That's what I heard too. Tilt it to the right side (passenger side if it were a car)....
Thanks for the all the input guy's.
snowman 700
- Oct 10, 2005
- Mid-Michigan
- 2011 Apex SE
2012 Vector (wifes)
Put it on the right side or oil tank side. If you put it on the left side gas can siphon out of the vent tube and make a mess in the garage and will melt the glue that holds the sound proofing down. Learned the hard way. I believe the Manual also says right side.
I have left it on the side all day for a track change. I put a pad under the side to keep from scratching. It also helps if you support the handle bar off the floor to balance and keep it from rolling too far over.
